Batch is breaking: Algorithm not effective (Clicks removal)
So I have hundreds of files which I pass through a batch. The batch has an item to remove clicks. And at some file it cannot remove clicks (so what - I don’t care really…) and then it just exits! So it’s breaking my batch leaving NO options to proceed. Is there any way to make this non-fatal?
What is the purpose of this?
Why don’t you care if the effect works? (If you really don’t care if it works or not, why bother running the batch at all?)
