DrO3k
July 4, 2024, 8:15am
1
I have a tonne of samples that I need to convert from various sample rates and bit depths into 16bit 48KHz.
A lot of the samples also have long sections of unwanted silence at the end of the samples that I want to crop.
How do I do these as batch actions in Audacity?
Is there an automated way to do it?
Can someone point to a step-by-step or tutorial, or even give me a step-by-step here?
Thanks.
I can offer the following option. Write a macro:
01 Select All
02 Truncate Silence.
03 End
Import a lot of your samples simultaneously, apply the Macro and Export as Multiple Files (choose desired Sample Rate)
DrO3k
July 4, 2024, 10:32am
3
Thank you, is it possible to automate the export process too with a macro?
VP2024
July 4, 2024, 10:44am
4
I tried, the export in the macro does not work
DrO3k
July 4, 2024, 1:00pm
5
Thanks. I just tried to add ‘export’ to macro and it didn’t work for me either.
system
Closed
August 3, 2024, 8:16am
6
