Batch conversion from AU to WAV
Hello,
I am using Audacity 1.3.13- beta on my Fedora 14 32-bit machine. I have a huge list of files (around 1000) in AU format spread across 10 folders, and I want to convert them into WAV format. I cant be opening each file in Audacity and then do File->Export and select WAV for each of these 1000 tracks. I want to know if there is some batch method that recursively goes through all the sub-folders in a folder, checks all the files that are AU and converts them to 16 bit WAV file format. Best solution would be if I can run this from the command line. Could someone help me out regarding this please ?
Please read the pink panel above
Audacity 1.2.x and 1.3.x are obsolete and no longer supported.
Do not interfere with the AU files.
You just need to open the saved AUP file or files that those AU files belong to. Please see:
Audacity Manual .
