Hi, I have windows vista and audacity 2.0.6, can you let me know whether it is possible to change the balance in the recording? I have a taper with the right channel lower than left channel and I would try to adjust this lack. Thank you!
You can use the balance control to the left of the blue waves. You need to use the bouncing green sound meters to set it. The effect doesn’t appear on the blue waves. The change affects the export.
