Hi everyone,
When I listen to my recording, I have a very loud background noise which sounds like “chhhhhhhhhhhh” . Where does it come from and how can I remove it? Thanks for your answers!
Noise is an analog problem. Probably from your microphone preamp. Or possibly it’s acoustic noise that you’re not noticing until you record & amplify.
Tell us about your setup and what you are recording? Are you using a built-in soundcard?
