Avoid recording external noiseand how to set the microphone
Hello to you,
The problem with Audacity I am facing is when I trybto record the music from the Internet, any noise that comes comes outside the hp notebook gets recorded also and Inthink that microphone should be set to the loudest sound coming from the notebook and ignore any sounds that are outside the notebook, like me coughing, fan working or any movement that makes the noise.
Hope you assist me with the issue and Inwould extremely thankful if I won’t be forced to be quiet as a fish and not make any noise that will make the recording defective.
Thanks in advance,
Eduard Malikin.
You are recording your laptop microphone.
http://manual.audacityteam.org/o/man/tutorial_recording_audio_playing_on_the_computer.html
