Autotune
Il programma si istalla correttemente, ma Autotune non si istalla.
Qualcuno può dirmi come posso rimediare?
The program installs correctly, but Autotune does not install.
Can someone tell me how I can fix it?
Autotune does not support Audacity.
There is a list of supported host applications on their website:
https://www.antarestech.com/host-daw-compatibility/
I think that the 32-bit VST version of GSnap should work, though the MIDI features are not supported by Audacity:
https://www.gvst.co.uk/gsnap.htm
The pitch-correction part of Graillon2 (free version) works in Audacity in Windows …
https://www.auburnsounds.com/products/Graillon.html
https://youtu.be/_al9aHLkoJU?t=8m15s
