Hello! Each time I manipulate a clip (edit audio, or move a clip) the name changes and I have to listen to the clip again, confirm what it is, and rename it. This is time consuming and a great workflow interrupter. I recall this happening years ago with a different update, but wanted to let you know. My work is all deadline oriented, radio journalism, and losing then correcting clip names is a giant pain.Thanks.
Muse are working on this.
See:
Peter
Hi! I understand how frustrating it is to constantly rename clips. To streamline your workflow, try using labels to keep track of your clips without renaming them. Also, check Audacity’s preferences for any settings that might affect clip names, and consider updating or reinstalling the software to fix any potential glitches. If the issue persists, reporting it to Audacity’s support team might be helpful. Hope this helps!
