Hello!
I’ve been using Audacity for quite some time now (newest version available) and do encounter following problem:
I have downloaded something called “Voicemeeter” which seems to be a realtime EQ+COMP that monitors your voice input and changes it to certain preferences.
Now this thing happens and I’m not sure if it’s due to the program, or audacity:
I am perfectly able to record my first track without any delay or time shift, but when I already do have a first track (be it my own record or some important instrumental) the second and all following one will automatically time shift a bit vorward. even before the start so to speak.
2 Arrows also show this on the left side of the track just as if I would have done it on my own.
Now just moving the track to a later point does not work as the sound still is not on point with my first track and I would have to fondle every track into its right place.
Anyone got an idea what I could do about that? I’ve looked all over audacity help manuals without success
Using newest audacity version, Win10 64-bit. internal sound card, “virtual cable” sounddriver. everything should be properly installed.
