Hello. I downloaded the new release of audacity 3.0.2 but I still have problems on several recordings.
I register and save the work done without problems.
I open the .aup3 project and all the tracks of the work appear (backing track and multitrack recorded voices)
BUT they are all completely empty !!!
It does not happen with all saved projects and even with some of these you can first open them regularly and then everything disappears if you try to access them again
I state that I have been using audacity for many years without ever having had these problems.
Thanks for your help
Itâs possible that could cause the problem if the project is on a cloud drive or network drive while the project is open.
Always ensure that the AUP3 project file is on a normal internal drive before opening the project.
Always save projects to a normal internal drive.
It should be safe to move a project to cloud storage after you have closed down Audacity, provided that you move it back to a normal internal drive before opening the project.
For important projects I like to have at least two backup copies on different drives as insurance against hardware failure.
I now have the same problem. Last days all went fine, today I try to open the file and it is empty! I reopened antohter file successfully and worked on it and saved it, and than it was empty when I reopened.
But in the file description it shows content (size 328 KB). What can I do?
Which version of Audacity do you have?
The current version is 3.1.1 - if your version is older, you can get the latest version via the Audacity website: https://www.audacityteam.org/download/
Updating will probably not recover your project, but may prevent the problem from happening again.
have tried to recover a version with Wondershare. It gives me a âaup3-walâ file which I cannot open on my mac. Any Idea? It is too big for an online converter (but it has content, which gives me hope.)
The â.aup3.walâ file is a temporary file used by Audacity while working on a project. When a project is properly closed, any data that is still required by the project is written into the â.aup3â file and the â.aup3.walâ file is automatically deleted. The âaup3.walâ file on its own does not contain any data that can be recovered - itâs a sort of âscratch padâ for Audacity.
I have now updated to 3.1.1. Can you confirm that it will not happen again that I just find an empty file the next day?
I am scared to use Audacity again to not lose my files.
this is what it tells me when I now tried to save it:
âtimestampâ: 1636714253,
âevent_idâ: â3e77cd16d8944e67b78f343005373fbcâ,
âplatformâ: ânativeâ,
âreleaseâ: âaudacity@3.1.1â,
âcontextsâ: {
âosâ: {
âtypeâ: âosâ,
ânameâ: âMacintoshâ,
âversionâ: â10.16.0â
âexceptionâ: {
âvaluesâ: [
âtypeâ: âWarningâ,
âvalueâ: âDisk is full.\n\nFor tips on freeing up space, click the help button.â,
âmechanismâ: {
âtypeâ: âruntime_errorâ,
âhandledâ: false,
âdataâ: {
âsqlite3.rcâ: â11â,
âsqlite3.contextâ: âDBConnection::CheckpointThreadâ
So, Iâll make you the same deal I have made with the others. If you zip up your .aup3 file, then upload it to a public server and post (or PM me) the link, Iâll take a look at it.
