As someone whose technological skills are at the Computer 101 Remedial level, I would greatly appreciate any answers,opinions and/or assistance members of this forum can provide. I am a former DJ of a local radio station who is no longer able to continue in this capacity. However, i have be offered an opportunity to do a show online from my home. In the interest of full disclosure, the show is an oldies show (vocal group harmony aka doo wop) as I grew up in the 50’s.
This will require purchasing some equipment in order to make an audition CD with music and narration. In other words, submitting a copy of my show for consideration.
I have used Audacity extensively for cleaning up songs sent to me from vinyl recordings as I can eliminate drop and pickup sounds from the record player and moderating all of the songs for use on a CD. What I haven’t done is added narration. So, for anyone who done this I would appreciate your input. I need a microphone and it has been suggested that I purchase a Yeti Blue Pro. Has anyone used this mic with Audacity? If not, could you offer the name of a good option as sound quality is paramount. Do I need a mixer? If so, any models you have used successfully? Where can they be obtained?
Thank you for your time and cooperation. I welcome any suggestions or recommendations you might offer and look forward to your replies.
Les Taylor
Moderator note: I have removed your email as 1) you really don’t want spambots harvesting your email from a public forum - and 2) we like to keep all discussions on the forum so they are readable by all and all can benefit.
I’ve never used one, but I believe the Yeti is a fine microphone. You’ll also need a good quiet & “studio”, and some sound absorbsion wouldn’t hurt. The acoustics (and your voice ) are probably more important than the mic as long as the mic is of reasonable quality. You can always adjust the “character” of the sound with EQ.
I am a former DJ of a local radio station…
… the show is an oldies show (vocal group harmony aka doo wop) as I grew up in the 50’s.
Just to be clear, the music is recorded right? No live music?
Here’s the issue - USB mics are no good for “live” real-time mixing. In general, you can only record from one device at a time. That also means that you cannot use two USB mics to record in stereo (at least not easily). So if you want to do your show in real-time and record it, that’s not what I’d recommend. However, if you want to record your announcing-narration and then mix it with music in post-production, a USB mic is great, and you won’t need a mixer… you can mix in software.
The convenience (and low cost) of a USB mic is very tempting. However, personally I’d probably choose a regular analog mic and a separate USB interface, because I’d have more flexibility to use the mic live with a mixer or in multi-mic recording, etc. And most microphones can last a lifetime, but you never know when USB is going to be replaced by something else. (I’m sure USB will be around in 5 years, but lots of people have mics that are 30-years old or more.)
Both Blue and Shure make good XLR-to-USB “adapters”, or there are all kinds of [u]USB audio interfaces[/u] with mic preamps & XLR connections. (If you get an analog “studio condenser”, make sure the interface provides the required phantom power.)
Of course, you don’t want to use a regular 'ol soundcard with a microphone. The built-in preamps are often low quality and it’s the wrong interface for a good recording/performance microphone (low-impedance balanced with an XLR connector). (The line-input on a soundcard is often acceptable for line-level sources.)
