audiotrack name
how can i disable audiotrack name? It flashes constantly when I move the mouse over it, it is very annoying
These are the new clip handles, you can grab onto it to move the clip around. It replaces the time shift tool, and cannot be disabled.
Double click on the name and press DEL.
Do you mean that the “name” flashes, or that the “Clip Handle” flashes?
The “Clip Handle” (drag bar) is highlighted on mouse-over, which indicates that the mouse is in the correct region to click and drag the clip. (see: Audio Tracks - Audacity Manual) This cannot be disabled.
The “name” should not flash (other than the Clip Handle being highlighted).
