Audio tracking falling out of sync
Running ver. 2.1.2 on a Windows 7 machine
I’m having trouble editing to audio files together as after a while (5-10mins) they are noticeably out of sync.
One file is recorded straight into Audacity 44100hz, 16-bit. The other recorded on a portable Tascam - 44.1k hz, 16 bit wave file.
Can anybody help me out as I’d driving me nuts?
Thanks.
Effect > Change Speed. Put the longest two clips on the timeline so you can figure out the difference with the best accuracy.
Your soundcard? I believe the Tascam.
