I’ve had this issue from the beginning - and can’t find any instructions how to fix it in the Manual.
whenever I set the labels (on the labels track) underneath an audio track I am editing eg with some editing notes or markers, and then edit the audio track in a way that it changes its length hence the position on the timeline - the labels do NOT move with the now repositioned audio points they are supposed to be associated with.
I have to move them manually to the relevant points on the timeline which are now in the new locations.
Clearly, I’m doing something wrong or missing a sync step, as I can’t believe that the labels cannot be synced with the audio track (not the timeline itself).
Ths sync-lock is syncing not just the label track to the audio track right above it (which is what I was looking for) - but ALL TRACKS in the project!
as I work with multiple tracks and often have a label track underneath each of the voice tracks (up to 4), and continue editing my music track - I can’t have ALL of them to be moving in sync as this creates chaos in my workflow - only one label track with one audio track right above it.
Can this be done?..
to rephrase my question - can I sync-lock a label track to ONE specific audio track?
It explains (or at least I, as the editor of that page, hope it does) how to achieve multiple sync-locked groups each delimited by a label track - there is a picture on that page to aid understanding.
