I am having some issues with the recorded audio skipping. This appears to only happen once, at the 2 second mark, of each recording. This audio “glitch” is not present in the source audio of course.
I have attached a 6 second clip of a well known song, you can clearly hear the “glitch” at the 2 second mark.
the control panel was set slightly higher, at 48000hz. I brought it down to match the 44100, saved the settings, but oddly this had no effect.
bumped audacity up to 48000 and no more skips
strange but it works
If you want to use 44100 Hz (CD standard), check in both the recording and playback settings in the Control Panel and ensure that everything is set to 44100.
