I had a serious crash and had to replace my hard drive, so I lost Audacity. I successfully installed Audacity, but not Lame. I downloaded Lame to a folder, and see it there when I open the folder, but Audacity preferences won’t recognize it when I browse from there, and it continues to say it’s not found. ??
Did you get Audacity from here: http://web.audacityteam.org/download/
If not, please remove your current version and download the 2.1.1 version from the links on the above website (we then know for sure that you are using a genuine version of Audacity.
Try downloading Lame_v3.99.3_for_Windows.exe from [u]http://lame.buanzo.org/#lamewindl[/u] and run the EXE file to “install” LAME instead of trying to copy it to a folder.
