My audio seems a little muffled, and it’s really ticking me off Can someone tell me how to fix this? Thanks!!
-Cole
-Cole
You can start with the info in the pink band above and then flesh out your question a little using these hints:
http://www.kozco.com/tech/audacity/Documents/PostingQuestions3.pdf
Audacity 2.1.X is capable of real-time adjustment of effects.
If you are using windows there are free equalizer plug-ins where you can immediately hear the consequence of say boosting the treble to make the sound less muffled, see the ogg video here … https://forum.audacityteam.org/t/version-2-1-1-0-doesnt-remember-equalization/39205/5
