Audio Recording checkpoints
I don’t believe there is a feature like this but I would find it immensely valuable.
I record scripted narration for a youtube channel. Often I will record each sentence of a longer take a few times. 99.9% of the time I’m only interested in the last take of any given passage but editing out all the other takes is very time consuming.
The tool I would love would work like this: I would start recording and say a sentence, if I’m happy with that sentence I would press a key which would checkpoint at the end of the sentence and recording continues. I would say the next sentence, and if I decide to record it again, I would press a different key which would skip back to the last checkpoint erasing my take since the last checkpoint. I would keep doing this until I have a sentence I like then I would checkpoint again and continue.
This would eliminate 95% of my editing and save me many hours as I would only have the takes I like. Thank you for considering this request.
What happens if you have a few more goes, and then think that the first take was actually the best one?
You could add a “marker” (label) at that point (“Ctrl + M”). See: http://manual.audacityteam.org/man/label_tracks.html
For the massive gains in productivity, I’m willing to take that risk. Worst case the last take is usable, but it’s also almost always the best.
I could also checkpoint the same words more than once if I want to give myself options. Almost always it’s takes I know are trash, like I misspeak or stumble a little that are the ones I want to dump immediately.
You could add a “marker” (label) at that point (“Ctrl + M”). See: > http://manual.audacityteam.org/man/label_tracks.html
I do occasionally use labels when I’m editing as sometimes I have enough takes it becomes confusing. This helps me keep them straight as I cull. But that’s cumbersome and only useful when I’m editing. I haven’t tried during recording, but I have Audacity recording in an unfocused window, so it’s not going to work for me.
If I can avoid having the takes I know I don’t want at all it would be a large help.
There a three press combination:
Space → Ctrl + Z → R
Unfortunately Audacity does not yet support macro commands, but if you want to use “Ctrl + Z” a lot, then you could reassign the shortcut to a single key. See here for customising shortcuts: http://manual.audacityteam.org/man/keyboard_preferences.html
An alternative would be to use an automation program such as AutoHotKey to automate "Space → Ctrl + Z → R " as a single key press.
Improving and extending automation in Audacity is one of the areas that is currently under development.
