audio problem
version 2.1.2just upgraded to version 2.1.2 after evrthng seeme to work fine except when i press record, there is no audio. but if i just want to play the song itplays the son fine.
What are you trying to record from? i.e. From a microphone? Vinyl records with a USB turntable? Streaming audio? Something else?
Make sure you’ve selected the correct [u]Recording Device[/u] for whatever you’re trying to record.
Thanks for reply Doug. recording from a rode mic, xlr cable from mic to external sound card.
Choose the mic input of the external sound card as recording device in Device Toolbar.
If the track you want to record against isn’t playing, enable Transport > Overdub.
