Bryan88
1
Hi guys! Been using audacity for awhile but for some reason when I record - the audio is super quiet with alittle staticy noise as well.
I’ve replaced the cables, made sure it was stereo, ALSO moved the bar for recording/volume as well.
Never had a problem until now - and when using mic for everything else it works perfectly. Any ideas?
DVDdoug
2
Make sure you’ve selected the mic as your Recording Device.
If you are on Windows, check your Permissions/Privacy Settings.
Make sure Windows “enhancements” are turned OFF.
Bryan88
3
Hi! Those are all correct and still no cigar.
Audacity IS picking up my mic, it’s just super quiet with alittle static in background.
I have my recording volume and playback volume maxed out. Can’t seem to figure this out
system
Closed
4
