Hi guys,
I’ve made an audio comparison of the three interfaces. The recordings were made using Fender Standard Strat. Shows the difference in sound of the amplifiers and convertors. When i was searching for the right interface, I searched for comparison videos but didnt find anything. So I made this.
Settings are the same.
You choose!
Which one did you like?
As far as I can tell they are all the same (which doesn’t really surprise me). So I would choose based on features. Congratulations on a putting together the test well, matching the levels is the most crucial part of any A/B testing as otherwise the louder one almost always sounds better.
Is the E-mu 202 still available? It sure seems to me that the Creative/Soundblaster folks are trying hard to kill of that line of products.
So. Um. Harumph. You didn’t hear any difference?
