Is there an easy way to take a small sample of the graph and maually remove one or more (single) data points on the X axis and leaving that spance blank- (not interpolate or delete the blank time data point?
I’m not quite sure what you mean by “not interpolate or delete the blank time data point”. Do you mean remove a data point but don’t move the following audio to fill the space?
If that is the case:
- Zoom in
- Select the point(s)
- Click on Edit > Remove Special > Split Cut
Alternatively:
- Zoom in
- Use the Draw Tool to move the data point to zero
– Bill
