Is it possible to record audio in the following format?
PCM 8KHZ, 16 bit, Mono
We have a program that specifically needs this audio format as it is used over normal telephone lines?
Yes
Look in
“Edit > Preferences > Audio I/O”
and
“Edit > Preferences > Quality”
to set the defaults.
Note that in Audacity 1.3.5 you can record in any format, then select your destination format when you Export your finished project.
Thanks for the Quick reply. Will give it a shot.
