Audio format exporting
while extracting audio from vudeo file, I would like to keep the format same as original video file. I want to extract and not to convert.
Audacity will be decompress (decode) it when you open it. You can re-export it in the same format but it’s not exactly the same digital data.
You’ll need to have FFmpeg installed for most audio formats in video files. You can use MediaInfoOnline to check the existing format & details.
There are demultiplexing tools that can separate the audio & video without decoding/re-encoding. I THINK XMedia Recode can do it.
Search Demuxer
