macOS High Sierra 10.13.4
Audacity 2.1.1
I did the same thing to two files, but two different things are happening now.
File1 [name:Ep 1 Introduction Episode.aup]: I opened the recording, then imported a .mp3 file (the intro to the podcast) to cut into the recording, it played fine so I hit “save” then closed the project. Now, when I try to open the file, a window pops up that says “Project check of “Ep 1 Introduction Episode_data” folder detected 104 missing audio data(.au) blockfile(s), probably due to a bug, system crash, or accidental deletion. There is no way for Audacity to recover these missing files automatically.” Then I select the option to “Treat missing audio as silence (this session only)” the entire file is empty.
File2: [name: Ep 2. Parents We Thought We’d Be EXP.aup]: Same thing as before. I opened the recording, then imported a .mp3 file (the intro to the podcast) to cut into the recording, it played fine so I hit “save” then closed the project. However, now when I try to open the file, a window pops up that says "Error Opening Project: Couldn’t find the project data folder: ‘Ep 2. Parents We Thought We’d Be EXP_data’ ". then another window pops up and says "Error Opening Project: Could not load file: ‘/Users/Kristen/desktop/…/Ep 2. Parents We Thought We’d Be EXP.aup’ ".
Is there any way that you know of to get these files to open again?
