I recorded something a few days ago and played back that it worked, but then today went to go transcribe from it and it was gone. The timeline is still there but it completely flatlined and nothing will play.
I am a reporter so I don’t really know much technically about this, I just recorded an interview.
Does the timeline still start with 0 (right now) on the left? I’m leery about telling you shortcuts because I really have no idea what happened. I could make it worse.
Leaving a show up like that is a pretty bad idea. You may have lucked out on the first one, but computers aren’t non-moving and non-changing machines. You may have software that likes to update itself and change the computer a little while it’s working. So the computer now isn’t quite the same machine it was a couple of hours ago.
Best idea is to File > Export: WAV (Microwave) when you get done. Those are perfect quality sound files and you can edit them into anything else. You can save the show open, too, if you want, but that’s the go-to way to conclude a recording session. That can fail, but only if you like to record multi-hour presentations.
And no hits because you have a celebrity problem. No normal person would do what you’re doing. Same thing with people posting on the forum for all the others who have the same wacky equipment they do (0), or through some error, their equipment works far better than everybody else. Unicorn problems.
If it’s a straight recording, we could try something pretty simple. Edit > UNDO. Take good notes what happens when you try that.
Did you record this in Audacity or in some portable recorder that saved a WAV file that you imported into Audacity? Steve is asking about dependencies in case it’s a WAV file.
Did you do more than sleep the computer, like reboot it? Unfortunately the audio has gone in that case because the Mac deleted the Audacity temporary files when it restarted.
I left an email note for the poster to rejoin the forum.
My guess is no. I know producers who work this way. They go from meeting to meeting just opening up their machine, do stuff and then close it again for the next meeting. They might save their work at the end of the day. Nobody ever makes backups.
The key is the thin line. There are a limited numbers of ways to get from a show to a thin line and they should all respond to UNDO. DEL will not do it. DEL gives you a blank, white timeline.
