Audio Device Info crashes Audacity with VIA 8237 soundcard
Hi
Using the Audio Device Info crasher Audacity with VIA 8237 sound, Im using Puppy Linux Slacko 531. Audacity 2.00 and 2.01 behave similarly. Audio Device Info works okay with Creative Labs soundcard and Puppy Slacko.
Using JACK set to hw0,0 the error is still there, but setting JACK to hw0,1 makes it work okay. Here is a summary and commandline output-
Audacity with ALSA, Audio Device Info crash
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 3875
audacity: pcm_params.c:2249: snd1_pcm_hw_params_slave: Assertion `err >= 0' failed.
Aborted
Audacity with JACK, JACK set to hw0,1, Audio Device Info no crash
Audacity with JACK, JACK set to hw0,0, Audio Device Info no crash
ALSA lib pcm_dsnoop.c:612:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:1018:(snd_pcm_dmix_open) unable to open slave
Aborted
The selection of input device changes depending on the above settings, see screenshots
Thanks for the report.
Did you mean "Audacity with JACK, JACK set to hw0,0, Audio Device Info leads to a crash?
I am not a Linux guru. Steve is, but he is away.
Do you think there may be a problem with this VIA inbuilt sound - maybe it does not support Linux properly? You may want to check http://alsa.opensrc.org/Sound_cards or other resources for driver tweaks.
Should you be seeing identical mirror devices 0,0 and 0,1? Do the 0,0 devices crash when you record from them?
Does
arecord -l
also list these duplicated devices?
And why does Jack list the duplicate devices other than the ones you asked for?
Does Ardour or some other audio editor also crash with this VIA device?
If you still want to pursue this, a backtrace would be better than terminal output, using a debug package of Audacity.
Thanks for the answers and questions, will look into it.
It’s not just with Jack though. Without Jack loaded in crashes in ALSA mode. Will check soundcard info…
