Im using Ubuntu 12.04 and was using Audacity 2.0.0
wery fine recording and all
did get to my self external audio card alesis iO4 that works Cubase LE5
cont run in on my Linux so did continue to work in Audacitey
something strange happend (no mic detected- and if it is so…was recording me 2 sec- and then would block)
somehow did fix that- sometimes could record sometimes not
until now when
after giving comand record- my cursor block on rec botton
and computer have to be turnd off violently
did knew I did not fix my problem before- becouse- no resnebel explanation why sometimes Audacity records for 1 or 10 seconds external card mic- and then stop- and warns you on shifted time…you shuld fix- by CTRL T - but you cont do that- or no reaction on comand
did try all tips and tricks
now Im on 2.0.5
and my ploblem is even bigger
ok if audacety do not wont to detect my external audio card mic…that is on USB port- o man was so happy to get that equipmant working properly
but- if does blocking on internal mic- makes big problem to me
is there anyone could help me with this
if i was not precise enough- pleas warn me
and pleas escuse my gramar or speling mistakes
Thanks in addvance
Barkey
PS dudes do not wont to give me no help becouse wont me back on Microsoft- and Im rather solow this problem howewer than that
not realy sudo independent - if you know what I mean
Similar post merged by moderator
and need to be turnd off violentley
problem did start after did install 12.04 linux- did had 10.10 and 2.0 audacity that was working more than perfect together
after did update my self on latest version of linux and Audacity and after upgrading my self on USB external audio card Alesis IO4
problem with time seams to shoved up- would be recorded for 2 second or 15 second and would interupted by program
did try all
now finaly did instal 2.0.5 but problem is critical eror
now even if i pres record- /to found out is it internal mic on or USB device build in mic in function/ my program block so hard need to svitch of computer manualy
I did not found out neither one program so simple as Audacity working on Linux
and is really important to me to make this working properlly
but i do not have than knowledge
anyone willing to help?
thanks
Barkay
