AudacityToolbars detached from window
Hi I have just installed Audacity 2.3.2 on MacOS 10.14.3 (Mojav). The tool bars are detached from the main window and can be moved around the screen. Is this normal,or is this version bugged.
I think it’s caused by a minor incompatibility with a previous version of Audacity. I’m guessing that you had an older version of Audacity before upgrading to 2.3.2. Am I right? Do you know which version you had previously?
The fix is very easy, and you should only need to do it once:
“View menu > Toolbars > Reset Toolbars”
