Audacity2.2.2
Hi,I am trying to record from free internet radio & save to a USB drive.
Is Adacity the correct program for this? Thank you,58 convertible
https://manual.audacityteam.org/man/tutorial_recording_audio_playing_on_the_computer.html
Hi,waxycylinder,thanks for your quick response. I had just found the tutorial that you linked me to.
Looks like I’ve some reading to do,thanks for your help,58convertible
On Windows, using “WASAPI loopback” is usually the most reliable method (details in the manual: https://manual.audacityteam.org/man/tutorial_recording_computer_playback_on_windows.html)
Hi Steve, thanks for your info & the link. I’m working my way through
the manual etc. Kind regards,58covertible(JD(.
