Recently, everytime i record something with audacity the first few seconds arent recorded properly.
The recorded version miss some parts of the audio from the beginning of the audio.
Imagine i’d record the following sentence “Hello all, this is just a test to demonstrate my problem”
Outcome would like like this “Hello a-- -s is --st a test to demonstrate my problem”
Check that the sample rate for your sound card (look in the Windows Sound Control Panel) matches the “Project Rate” in Audacity (lower left corner of the main Audacity window.
The default project rate may be set in Preferences: https://manual.audacityteam.org/man/quality_preferences.html
thanks, this solved my issue. i dont know why this error occured recently tough.
anyway thanks again
