Sorry about the second post. Those lines come out fairly fast, then it pauses for the 3 minutes. Then this set of lines come out, fairly fast, then a brief pause and finally the main window launches. While this is happening the blue light on my web cam comes on for a while, blinks sometimes, stays solid for a while, etc.
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4541
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1670
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1830
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2092
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2764
And here’s what’s in the log
07:21:27: Audacity 2.0.3
07:25:55: Retrieving FFmpeg library version numbers:
07:25:55: AVCodec version 0x352300 - 53.35.0 (built against 0x352300 - 53.35.0)
07:25:55: AVFormat version 0x351501 - 53.21.1 (built against 0x351501 - 53.21.1)
07:25:55: AVUtil version 0x331602 - 51.22.2 (built against 0x331601 - 51.22.1)
I know this wasn’t asked for but I saw an “Audio Device Info” selection under help. When I select that I get a lot of output at the terminal window:
Expression 'parameters->channelCount <= maxChans' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1438
Expression 'ValidateParameters( outputParameters, hostApi, StreamDirection_Out )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1780
ALSA lib pcm_dmix.c:1022:(snd_pcm_dmix_open) unable to open slave
Expression 'AlsaOpen( hostApi, parameters, streamDir, &pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1702
And the following in a dialog box:
Default capture device number: 15
Default playback device number: 15
Device ID: 0
Device name: HDA ATI SB: ALC1200 Analog (hw:0,0)
Host name: ALSA
Input channels: 2
Output channels: 8
Low Input Latency: 0.011610
Low Output Latency: 0.011610
High Input Latency: 0.046440
High Output Latency: 0.046440
Supported Rates:
44100
48000
96000
192000
Device ID: 1
Device name: HDA ATI SB: ALC1200 Digital (hw:0,1)
Host name: ALSA
Input channels: 0
Output channels: 2
Low Input Latency: -1.000000
High Input Latency: -1.000000
Supported Rates:
44100
48000
88200
96000
192000
Device ID: 2
Device name: HDA ATI SB: ALC1200 Alt Analog (hw:0,2)
Host name: ALSA
Input channels: 2
Output channels: 0
Low Output Latency: -1.000000
High Output Latency: -1.000000
Supported Rates:
Device ID: 3
Device name: Microsoft® LifeCam Cinema(TM): USB Audio (hw:1,0)
Host name: ALSA
Input channels: 1
Output channels: 0
Supported Rates:
Device ID: 4
Device name: sysdefault
Host name: ALSA
Input channels: 128
Output channels: 128
Low Input Latency: 0.042653
Low Output Latency: 0.042653
Supported Rates:
8000
9600
11025
16000
22050
32000
44100
48000
88200
176400
Device ID: 5
Device name: front
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 6
Device name: surround40
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 7
Device name: surround41
Host name: ALSA
Input channels: 0
Supported Rates:
44100
48000
96000
192000
Device ID: 8
Device name: surround50
Host name: ALSA
Input channels: 0
Supported Rates:
44100
48000
96000
192000
Device ID: 9
Device name: surround51
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 10
Device name: surround71
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 11
Device name: iec958
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
44100
48000
88200
96000
192000
Device ID: 12
Device name: spdif
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
44100
48000
88200
96000
192000
Device ID: 13
Device name: pulse
Host name: ALSA
Input channels: 32
Output channels: 32
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 14
Device name: dmix
Host name: ALSA
Input channels: 0
Output channels: 2
Low Output Latency: 0.042667
High Output Latency: 0.042667
Supported Rates:
48000
Device ID: 15
Device name: default
Host name: ALSA
Input channels: 32
Output channels: 32
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Selected capture device: 15 - default
Selected playback device: 15 - default
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Available mixers:
Available capture sources:
0 - Front Mic:0
1 - Rear Mic:0
2 - Line:0
3 - Front Mic:1
4 - Rear Mic:1
5 - Line:1
Available playback volumes:
0 - Master:0
1 - Headphone:0
2 - PCM:0
3 - Front:0
4 - Front Mic:0
5 - Front Mic Boost:0
6 - Surround:0
7 - Center:0
8 - LFE:0
9 - Side:0
10 - Line:0
11 - Beep:0
12 - Rear Mic:0
13 - Rear Mic Boost:0
Capture volume is native
Playback volume is native
I don’t use Audacity often. I think it’s been doing this for a while. In fact I thought it was just broken since it took 4 minutes to start I usually gave up. But this time I ran it and it got stuck, I went on the net looking for an answer when to my shock it popped up the window! The system has not changed hardwarewise. Of course the system has had many updates as I run the update-manager most days and install just about whatever comes along needing an update. I don’t believe this desktop system has any bluetooth hardware at all. If it did I’d probably use it.
