This has happened several times now. Whenever my computer dies, audacity doesn’t recover the old projects from the last session. I tried looking in the directory where it saves the temp files and it’s not there. I plugged my computer into the charger this time too, so I have no idea how it’s even possible that it died. So is there any way for me to get these files back? If not I can accept that… but how do I fix this so it doesn’t keep happening?
I got this from my roaming > audacity folder under lastlog
02:09:36: Audacity 3.3.3
02:09:36: sqlite3 message: (1) no such table: project in “SELECT 1 FROM project LIMIT 1;”
02:09:36: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
02:09:36: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: The specified module could not be found.)
02:09:36: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: The specified module could not be found.)
02:09:36: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: The specified module could not be found.)
02:09:36: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
