Audacity won't record - What am I doing wrong?
I have Audacity working on a tower, running Win 10 but on this laptop which also has Win 10 it won’t??
Version 2.3.3.
I would appreciate if someone can point me to the thread or post that can help me. Sorry to land this on you, especially as it’s my first post.
Hopefully, I have the settings that will help someone to understand what my problem is. My laptop is a Dell Latitude E6400 which is about as much as I can tell you.
Thank you very much for your time.
Audio Device Info:
Default recording device number: 1
Default playback device number: 5
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Recording channels: 2
Playback channels: 0
Low Recording Latency: 0.09
Low Playback Latency: 0.09
High Recording Latency: 0.18
High Playback Latency: 0.18
Supported Rates:
Device ID: 1
Device name: Microphone / Line In (2- IDT Hi
Host name: MME
Supported Rates:
Device ID: 2
Device name: Dock Mic (2- IDT High Definitio
Host name: MME
Supported Rates:
Device ID: 3
Device name: Internal Mic (2- IDT High Defin
Host name: MME
Supported Rates:
Device ID: 4
Device name: Microsoft Sound Mapper - Output
Host name: MME
Recording channels: 0
Playback channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 5
Device name: Speakers / Headphones (2- IDT H
Host name: MME
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 6
Device name: Independent (R.T.C.) Headphones
Host name: MME
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 7
Device name: Primary Sound Capture Driver
Host name: Windows DirectSound
Low Recording Latency: 0.12
High Recording Latency: 0.24
Supported Rates:
Device ID: 8
Device name: Microphone / Line In (2- IDT High Definition Audio CODEC)
Supported Rates:
Device ID: 9
Device name: Dock Mic (2- IDT High Definition Audio CODEC)
Supported Rates:
Device ID: 10
Device name: Internal Mic (2- IDT High Definition Audio CODEC)
Supported Rates:
Device ID: 11
Device name: Primary Sound Driver
Low Playback Latency: 0.12
High Playback Latency: 0.24
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 12
Device name: Speakers / Headphones (2- IDT High Definition Audio CODEC)
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 13
Device name: Independent (R.T.C.) Headphones (2- IDT High Definition Audio CODEC)
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 14
Host name: Windows WASAPI
Low Playback Latency: 0.003
High Playback Latency: 0.01
Supported Rates:
    48000
Device ID: 15
Device name: Speakers / Headphones (2- IDT High Definition Audio CODEC) (loopback)
Low Recording Latency: 0.003
High Recording Latency: 0.01
Supported Rates:
Device ID: 16
Supported Rates:
    48000
Device ID: 17
Device name: Independent (R.T.C.) Headphones (2- IDT High Definition Audio CODEC) (loopback)
Supported Rates:
Device ID: 18
High Recording Latency: 0.0101587
Supported Rates:
Device ID: 19
Supported Rates:
Device ID: 20
Supported Rates:
Selected recording device: 18 - Microphone / Line In (2- IDT High Definition Audio CODEC)
Selected playback device: 11 - Primary Sound Driver
Supported Rates:
    44100
Available mixers:
Available recording sources:
0 - Master
Midi Device Info:
Default recording device number: -1
Default playback device number: 0
Device ID: 0
Device name: Microsoft MIDI Mapper
Host name: MMSystem
Supports output: 1
Supports input: 0
Opened: 0
Device ID: 1
Device name: Microsoft GS Wavetable Synth
Host name: MMSystem
Supports output: 1
Supports input: 0
Opened: 0
No MIDI recording device found for ''.
Selected MIDI playback device: 0 - MMSystem: Microsoft MIDI Mapper
Available playback volumes:
Recording volume is native
Playback volume is emulated
What are you trying to record from? The microphone built-into your laptop? Streaming audio? Etc.?
Hello thanks for your reply.
I am learning languages, and I’d like to be able to record the target language(s) that is/are being spoken to from sites like Youtube. I am not into ripping music off the internet etc, I simply want to record what I can hear spoken through my speakers/headphones.
Tonight, the internal microphone could hear me clapping my hands, but I couldn’t get it to record a gentleman speaking Polish to me from an MP3 file. The purpose is so that I can put the files onto my phone to listen to as I do my day job.
Thank you
I’m still trying to record - Please?
Select [u]WASAPI loopback[/u] as your [u]Recording Device[/u]. Apparently, you’ve selected the microphone.
I have the same problem… it used to work, but after I installed the Scarlett controller software, it quit on me… I am running a Focusrite Scarlett into a Windows 11 laptop… It just records a flat line when I hit record regardless of if it is set to MME, widows direct sound, or WASAPI… And when I select Focusrite USB loopback, Audacity does nothing at all. I have tried everything. Someone please help!!
