Audacity won't load due to security software [SOLVED]
I just downloaded the current version of Audacity and installed on my Windows 10 machine. Everything seemed to go fine, but when I started it up, I got a message from my Kaspersky security software that said the application is not allowed to receive audio stream. The splash screen with the logo was up, but it didn’t finish loading. I reconfigured Kaspersky to allow the audio stream and restarted the application, but it hung on the splash screen again.
Any ideas of what to look for?
Did you download Audacity from here: http://www.audacityteam.org/download/windows/
What is the exact name of the file that you downloaded?
I finally got it to work. I ended up rebooting a second time and it worked fine from there.
Thanks
