Audacity will not load...missing aop-ms-win-crt-runtime-
windows missing api-ms-win-crt-runtime .dll
What version of Audacity are you trying to run?
For a possible solution, see: api-ms-win-crt-runtime-l1-1-0.dll is missing
Funny thing… Last night I searched my hard drive for api-ms-win-crt-runtime and it doesn’t exist on my computer (Windows 11).
I’m at work on Windows 10 now and Audacity is installed but search is “not cooperating”.
BTW - Is it api or aop?
And did you down the official Audacity from audacityteam.org?
I was using an old widows 7 computer I use with my tv and sound system. I reloaded the old version of Audacity (2.0.3) after uninstalling the new version and deleting the remaining Audacity files. Now it loads and works great. DIRTYBIRD
