Audacity volume effects lose it
Every time when I’m using volume effects in audacity, no matter which settings, it makes the audio with silence only!
Audacity, THAT’S IT!!! IF I CAN’T FIX IT I WON’T USE YOU N.E. MORE!!! YOU RUINED YOUR SOFTWARE BECAUSE TODAY TECHNOLOGY IS SO STUPID, BROKEN AND CAN’T WORK JUST LIKE WE WANT!!! YOU SHOULD SAY SORRY AND FIX YOUR SOFTWARE NOW!!!
Someone help me please!
Please give us an example. Tell us what volume effect and what settings?
Have you tried a different file?
If you run the Amplify effect what does it default to for Amplification and New Peak Amplitude?
If I run Amplify, and I set it for an Amplification of -1dB, I get 1dB of attenuation, exactly as expected.
