The MetaData for the tracks --are already individually set. Export Multiple, undoes the existing MetaData, essentially causing the reentry of every field, except ‘Title Track’.
EXAMPLE:
Four imported tracks, two have ‘Artist: one’ with different track titles. The other two tracks = ‘Artist: two’ with the final two, out of four tracks, having their own respective track titles.
Audacity:
- will use the ‘track name’ of the top track, and place it in the applications title bar.
- Export Multiple | Export | MetaData Editor – will scramble the existing MetaData, in the following way
The first of four – the ‘Artist Name’ is populated with the last imported tracks ‘Artist Name’, while the ‘Track Title’ field correctly matches ‘The first of four’ track names, as-well-as matching the name in the Audacity ‘title bar’.
The balance of track one’s MetaData is populated with track fours info. In-fact, all four tracks are using incorrect MetaData with the exception of the ‘Track Title’ field.
Again, this MetaData for each individual file\track already correctly exists; it gets scrambled with Export Multiple.
OS: Win-10 (HOME), VER: 22H2, OS build: 19045.3086
Respectfully
