Audacity Themes Bug
So I finally got my mic to connect, and Audacity is allowing me to open it, but now none of the themes will load. The for the Light theme most of the buttons are blackened out, and for all for all of the others all of the buttons are blackened out. I tried uninstalling and then reinstalling, and rebooting, but so far nothing has worked.
The buttons don’t even clear up when I hover over them, and when I click on Audacity to run it, the Logo appears all black too. My cursor is suddenly becomes a black block any time I place it on the already black sections as well.
Anywho, any help would be greatly appreciated.
Thanks!
Which version of Audacity?
Where did you get it from, and how did you install it?
Sorry it took me so long to reply!
I am using Linux Bata, Audacity 2.2.2, and I installed it from Linux apps / software (tried both).
What is “Linux Bata”?
I don’t understand what you mean.
