Hello,
I hope you can help. I am experiencing a long-term issue with Audacity. It can take hours to save a lengthy recording, of approx 8 hours.
Is this correct?
Sometimes it can even take 20 or 30 minutes for a 1 hour recording. Is this usual?
I have experienced similar on different computers and versions, but I am currently on Windows 10 with Audacity 2.4.2. And it is happening again.
Would anyone be able to tell me how long it should take for 8-10 hour recordings to save? Or any information on this generally?
It can be quite a problem if I am trying to use Audacity again after recording, as I can’t get access again, sometimes for hours.
I loaded a 75-minute stereo WAV file on 2.4.2. It took 10 seconds to save to .aup on a hard drive on my laptop, but 120 seconds to do a subsequent Save As. And about 120 seconds to export as a .WAV file.
Do you have older spinning-metal hard drives? Newer machines can come with Solid State Drives which a are generally smaller and more expensive, but very much faster.
What are you doing to the shows? Effects? Cleanup? Audacity performs some UNDO by saving high-quality copies of the whole show. So your machine may be trying to manage 16 or 32 hour recordings when you save. If the machines are fragmented or starting to fill up—or both, that can be a massive job.
Audacity is a home audio editor and doesn’t work well for surveillance or long-term capture or archive recordings.
