Thanks guys…
I only do a couple things with Audacity…so I am not “experienced”…but I can do what I want to do…
DAT…Sony DTC-A7…connected SPDIf cables to the SPDIF connectors on the M-Audio Delta sound card…
Took a little fiddling around but I am recording from the DAT…DAT is connected to the coax connectors on the DAT…
Now…I think I was a little misleading…
I am NOT having an issue with the DAT…
I mentioned the DAT in my original post as I thought maybe I changed some setting to get the DAT to work…
and maybe that was my what was causing my problem…I now think that is NOT the case…
I am having problems with files that I have already ripped and exported them as WAV files…These files were taken from
a live recording from a Zoom H2 digital recorder…
Time sequence…
Thurs I connected the DAT…got it working and ripped an entire DAT tape and exported it as a WAV file…
I edited the file…broke out about 15 different tracks…
Fri…did no work on the system…
Sat…I did a live recording on the Zoom H2…WAV files…transferred those Zoom files to my DAW…
Opened up one of the files and started editing that file into 11 different tracks…(bluegrass band)…
Then I started cleaning up the tracks…did 6 of them when I started having problems…
That’s where I started in my original post…
I now believe it is something in my PC…I’ve done some cleanup work but so far have not found anything amiss…
I then loaded Audacity up on a DIFFERENT PC…and am now editing the files I was having problems with…
I’ll do my audio work on the 2ed PC until I figure out what’s wrong with my DAW PC…
I will uninstall 2.0.5 again and will check here http://manual.audacityteam.org/man/preferences.html and try to get everything cleaned out…and reinstall 2.0.5 again…
Don;t think I want to upgrade to 2.1.2 until I know I have 2.0.5 working correctly again…
I hope I’ve answered your questions…Keep in mind…I have NO issues with the DAT…it is my previously recorded work that
came from a live Zoom recorder that is giving me issues…
Ok…I just tested the DAW by opening an old WAV file I did several months ago…the file opens up in Audacity…but will NOT
play…also…the"X" in the side panel…(don;t know the proper name for it)…will NOT close the file…have to close Audacity
to close the file…
