Audacity Stops Exporting/Crashes During Exporting
I need some help. Trying to export a podcast episode and I’ve tried to export it any way that I can. MP3, WAV, anything at this point. I’ve never had this problem before, but every time that I go to export, it stops exporting on its own before it finishes, and/or the entire program crashes. Please help
You ran out of room. I’d bet serious chocolate the drive has run out of room and won’t support containing another show. There’s just no place to put it.
Do you have a backup disk you can shovel some of your older work onto and make room? No is not a good answer here. How do you make safety backups of your shows?
This is Win10? Google ‘check the hard drive’. There’s different variations depending on your system.
What does it say?
