Hi,
Jusy installed Audacityy from the Audacity site with the exe installer . . .I’m on Windows 7.
Then I installed the LAME_v3.99.3 for Windows . . . . but my input devices are nothing . . . . just blank space . . I did a rescan and still nothing.
Also input channels are blank as well.
Sorry I don’t understand.
Is “Rec. Playback (IDT High Definition Audio Codec)” an option that you can see in Audacity, or in the Windows Sounds Control Panel, or somewhere else?
It is possible if the sound device has a “stereo mix” or “wave out” option (almost no sound devices have a real “audio CD” input that is connected to the CD drive).
