I have an iMac M1 running Sequoia 15.0.1, and my mic is a Blue Yeti usb. It recognizes the mic, but I cannot get it to work on Audacity. However, it works with other programs, so that is not the issue. Has anyone experienced this, and are there any solutions to my problem?
I’m a Windows guy but check your Privacy/Security Settings.
You’ll probably have to enable the USB mic separately from your built-in mic.
