I’m undertaking the monster task of recording my vinyl.
What I’m using:
Technics 1200 MKII with Grado Cartridges, using RCA/Phono to a Rega Fono Mini (http://www.rega.co.uk/fono-mini-a2d.html) USB A2D, using a 12 ft USB cable to a Win 8.1 x64 machine with 32 GB of RAM, and a Haswell i7 CPU.
I record at 16 bit 44.1K.
What happens:
Not all the time, but often enough to be quite annoying, all the sudden Audacity will stop recording. When you have 10 min songs and it stops 9 mins in-very frustrating. Most times it behaves like that, Audacity stops near the end of the song. I have to use play Software Play through to listen for skips, plus I haven’t heard many of these songs in a long time!
What I have done to try to fix the issue:
I have tried 3 different USB ports. 1-thru a USB 3.0 hub, 2-thru a front panel USB 2.0 port, and just in the last few days 3-thru a USB 3.0 port right on the board-no difference.
I have also tried changing the interface, starting at MME, going to Windows WASAPI, but also trying Windows DirectSound-no difference.
I have tried checking both “Allow applications to take exclusive control of this device” and “Give exclusive mode applications priority” on the Rega USB device (which just shows as “UBS AUDIO CODEC”-no difference.
Lastly, I have tried playing with the Latency-Audio to buffer, starting with the default (can’t remember what that was), going to double the default, 500, now at 1000 ms-no difference.
You guys are my last resort!! If you need any other info, about my setup please let me know. I have a history of working in a recording studio, using Pro Tools-can’t use it for this, long story, and I’m not used to having this much difficulty!! Any help would be greatly appreciated!
Thank you.
