Audacity problem with new lame version
Hello,
I am running Windows 7 64 bit.
I uninstalled an older version of Audacity and downloaded version 2.1.2. I keep it on a thumb drive.
I also uninstalled an older version of LAME and installed version 3.99.5. It is also kept on a thumb drive.
I’ve used this configuration (thumb drive) for about a year.
Suddenly, I am receiving two error messages from Audacity
  1. Cannot find lame_enc.dll. (or something like that)
  2. The version of LAME is not compatible with the (version) of Audacity (or something like that)
I have tried using the preferences>find the location of the dll etc. it didn’t work.
I assumed that Audacity would be compatible with the new LAME version but I am wondering if that is the case. ?
If I decide to reinstall on to the C:\ drive what path(s) would I direct the unzipped files to ?
Thanks
17bob3O
I’ve always downloaded the “Audacity version” of LAME from [u]here[/u], and I’ve installed it by running the EXE file. It’s version 3.99.3, but there’s nothing in the latest version that affects sound quality, and as far as I know nothing that would improve it’s use with Audacity ([u]LAME Changelog[/u]). 3.100 will have sound quality changes/improvements.
On my computer:
C:\Program Files (x86)\Lame For Audacity.
There is some information about that on [u]ths page[/u].
  1. The version of LAME is not compatible with the (version) of Audacity (or something like that)
I believe you need the 32-bit version even if you’re running 64-bit Windows, because Audacity is a 32-bit application.
