Audacity on Mavericks OSX v10.9.1
I have been using Audacity with OSX Leopard and then Snow Leopard with no problem. I recently upgraded to Mavericks OSX. When I try to start Audacity I get a message that power PC applications are no longer supported. Is there a work around for this?
Only ancient 1.2 versions had separate PPC and Intel builds. It’s strongly discouraged to use legacy 1.2 versions of Audacity in any case. See the pink panel above.
If you download the latest 2.0.5 from http://audacityteam.org/download/mac it is a Universal Binary that runs on Intel Macs (so it will run on Mavericks) and on PPC Macs.
Beautiful. Thanks for the help.
