So I want to make an “extended version” of the Death note OP for a fan project but i can’t manage to make it clean the sound quality is very different between the audio files and i can’t normalise it so it sounds the same. I am very new to those whole audio things so if someone could help me figure it out it would be greatly appreciated.
Basically i cut the OP version at 1:11:15s to put the end of the full version of the song but it just doesnt sound clean.
The main problem with the join is the stereo images don’t match, (not an equalization difference).
The first part has a narrow stereo image, (almost mono), whereas the end has a wider, (normal for pop) image.
A quick fix is to make your entire mix down to mono.
Then make it dual-mono, (duplicate to make two absolutely identical tracks, then join together).
Then apply a pseudo-stereo effect to that dual mono track to add some stereo width, (which now will be constant throughout the duration).
