Fail to open page with audacity nightly builds.
gaclrecords.org.uk/win-nightly
Please, tell correct adress.
Error message, when try to open:
Error in log on line 164.
./audacity-win-ra45f3bb-2.2.0-alpha-22-jul-17.zip is already defined.
That’s the correct address, but there appears to be a problem at the moment.
By the way, the situation did not improve.
What, now there will be no alpha versions? So the nightly builds does not work.
You know how it is; if it’s not one thing it’s another.
We had no Mac nightlies for while and I’ve just got them up again, but now the Windows nightlies are off.
I’ll update this topic when I have accurate information.
Well, which was the last one? Please send the link to download.
mmmmmmmmm… actually i see there’s a new daily build site… but apparently so many version it’s not present ? For example on my last usage i have this:
audacity-win-ra68f7fc-2.2.0-alpha-22-apr-17.zip
On new site the latest daily build it’s the 2.1.3 of febraury…i have also see the newest github… the 2.2.x developing continue on it ? We need to compile manually ?
Unfortunately Windows Nightly builds are not currently available because the person that was building them is in hospital and the machine that was building them has gone down. I hope that we will be able to bring back regular nightly builds of Audacity development code, but for now the only option if you want the latest alpha version is to download the source code from GitHub and build it yourself. The source code is available here: https://github.com/audacity/audacity
I will update this page as and when new information becomes available.
The most recent Windows Nightly build currently available is:
audacity-win-x9072628-2.2.0-alpha-14-jul-17.zip
https://www.fosshub.com/Audacity-Windows-Nightlies.html
I’m hoping that a more recent build can be added soon.
Download this (audacity-win-x9072628-2.2.0-alpha-14-jul-17.zip) version, the effect Limiter doesn’t work. Please, correct.
And the same report for Vocal remover:
Notch filter:
What has happened?
09:58:35: Audacity 2.2.0-alpha-Jul 14 2017
09:58:35: Trying to load FFmpeg libraries...
09:58:35: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
09:58:35: Looking up PATH environment variable...
09:58:35: PATH = 'C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Users\Юрий\AppData\Local\Microsoft\WindowsApps;'
09:58:35: Checking that '' is in PATH...
09:58:35: FFmpeg directory is in PATH.
09:58:35: Checking for monolithic avformat from 'avformat-55.dll'.
09:58:35: Error: Failed to load shared library 'avformat-55.dll' (error 126: не найден указанный модуль.)
09:58:35: Loading avutil from ''.
09:58:35: Error: Failed to load shared library '.dll' (error 126: не найден указанный модуль.)
09:58:35: Loading avcodec from ''.
09:58:35: Loading avformat from 'avformat-55.dll'.
09:58:35: Error: Failed to load FFmpeg libraries.
09:58:35: Error: Failed to find compatible FFmpeg libraries.
09:58:40: File name is C:\Users\Юрий\Music\11 маршрут1.mp3
09:58:40: Mime type is *
09:58:40: Opening with libsndfile
09:58:40: Opening with libmad
09:58:40: Open(C:\Users\Юрий\Music\11 маршрут1.mp3) succeeded
It looks like Audacity can’t link to any external applications.
I bet that MP3 export doesn’t work either.
No, unlike these effects, mp3 export normally passes. Please, send a normal version, in which all effects work.
There’s a new build on FossHub (4th Aug 2017):
This version is also no good. The effects work, but very slowly, more slowerly than before. Please, correct.
You’ve not given enough information for us to begin analyzing your problem.
Please give precise details, including comparisons with the same files on the same hardware with Audacity 2.1.3 release version.
Also, please give details of your equipment.
No, I’ll wait for the version on the old nightly builds site, when it’s released. And now it’s useless, nothing happens.
I don’t think there will be any more nightly builds on that site. The nightlies were planned to be moved to FossHub before the old site went down, but that didn’t happen due to the guy doing it going into hospital.
The official release version is the supported version and recommended for production use: http://www.audacityteam.org/download/windows/
