Hi,
I downloaded Audacity to a flash drive and then copied Audacity and installed it on to a laptop.
It installs but when I try to Export a file I’ve edited I get the error message…“Audacity needs lame-enc.dl”
I’m not sure what that means or where to find that file or how to “install” it into Audacity?
I’m running Windows 7 - 32-bit on a PC.
Thanks so much.
Download and run [u]Lame v3.99.3 for Windows.exe[/u]. That will install the Audacity version of LAME.
While you’re at it, you may want to install FFmpeg in case you need to import/export other formats that Audacity doesn’t natively handle.
Hi DVD Doug,
Thank you!
I didn’t get an email alert of your post so I checked back in and found your helpful post.
In my Profile it has a dot in the circle to accept email from members as well as administrators - not sure what went wrong.
Thanks again.
Make sure you are subscribed to the topic (bottom left of the topic page).
However you should also check your e-mail client’s Spam or Trash folders. Announcements from forums might be filtered there by default.
